How do you work this ???
Old Jul 1, 2009 | 01:40 PM
peterbr1723's Avatar
Default How do you work this ???
i have an audi a4 1997 right below the headlights theres something that squirts water into the headlights how do you make this work because i have no idea thank you
Old Jul 1, 2009 | 01:51 PM
dafrazi's Avatar
Turn headlights on and spray windshield washer nozzles. Headlight washers will spray too.
Old Jul 7, 2009 | 12:46 PM
'oooo''s Avatar
did every model have this option, i have a 2.8 v6 5spd and when i spray the windsheild washer fluid, nothing happens with the headlight, this would be very useful in the winter time!
Old Jul 7, 2009 | 12:49 PM
srlito's Avatar
I believe that the washers for the lights only came with the cold weather package.
Old Jul 7, 2009 | 02:41 PM
'oooo''s Avatar
ok, so i went out and manually pulled up the little squares on the bumper, and the nozzles are there but they wont spray! is there a secondary pump for these, i would really like to get these working
Old Jul 7, 2009 | 05:40 PM
copper07's Avatar
There is a secondary pump, mine had come lose and the washer fluid was not getting to the headlights.
Old Jul 7, 2009 | 06:00 PM
gen2roller's Avatar
+1
The lights have to be on for them to work as well.
Old Jul 7, 2009 | 07:27 PM
'oooo''s Avatar
so if you look right behind the drivers side headlight you can see the secondary pump right? when your's came loose what did you do to fix it? even though its right there it seams hard to get at
Old Jul 8, 2009 | 11:23 AM
copper07's Avatar
The secondary pump is on the washer fluid tank. I had to take the wheel off, remove the plastic from around the wheel, and then remove the washer fluid tank. It took some time.
mmhyson
Jun 8, 2009 07:19 PM
971.8t
Mar 27, 2008 01:07 PM
quattrocket
Nov 22, 2005 04:45 PM
