How to make my engine rev quicker
Old Jun 19, 2009 | 02:39 AM
a2thy's Avatar
Default How to make my engine rev quicker
Does anyone know why our engines are designed to wind up and down so slowly? I drove my friend's 1.8t Jetta and could make the RPMs jump right up and down as if there was very little resistance. I had a 15lb steel flywheel installed on my car during my clutch job, but it didn't seem to change this problem very much. I've heard of a lightened crank pulley for our cars but also heard it throws the engine out of balance. Is there any safe reliable way of making the engine wind up and down quicker?
Old Jun 19, 2009 | 07:30 AM
hiwords's Avatar
yes, a fully built engine but that'll cost you grands
Old Jun 19, 2009 | 10:55 AM
ghost6303's Avatar
9 pound flywheel, knife edged crankshaft, lighter pistons/rods, lighter and/or underdrive pully set (which isnt really a good idea).
Old Jun 19, 2009 | 11:14 AM
Mike-2ptzero's Avatar
The dual mass flywheel on the A4 makes the rpms and throttle response feel very lazy. Even going with a single mass steel flywheel will make the engine respond much quicker to throttle changes. Another thing is the dbw setup, most tuners try to increase the throttle response by changing the value.
Old Jun 19, 2009 | 07:50 PM
a2thy's Avatar
I actually plan on getting a fully built engine around the time my car is due for its next timing belt. I'm just trying to learn a little more about engine mechanics and such first.
I was actually thinking of doing what you're suggesting not to do, ghost. What's the reason it's not such a good idea?
I actually had a 15lb single mass steel flywheel installed and didn't notice much, if any of a change in throttle response. Should I have gone lighter?
How does this work? Can I do it with my VAGCOM on my 2001?
This abundance of new information kinda' makes me feel like a noob, lol.
Old Jun 20, 2009 | 11:48 AM
You should have seen some difference in how he engine rev's up with that flywheel since its close to 10 lbs lighter then stock. If you didn't then something else is causing the engine to have poor throttle response.
No you can not, it has to be changed by the tuner, my old GIAC chip was set to go WOT once I hit 25% of the throttle. It was set that way since I raced the car nearly every weekend.
Are you running a chip? Beause I dont see one listed in your sig.
Old Jun 20, 2009 | 04:50 PM
a2thy's Avatar
The lighter flywheel may have changed it a little, but I didn't notice. Guess I should have made some measurements or something.
Something else I just thought of, didn't think it might be related to this until now. Every time I launch, the power and RPMs go down for a fraction of a second before I get any decent acceleration. This happens about one second after the car starts to move and causes the car to "chug" regardless of how perfect my clutch/gas pedal footwork is. I know the clutch needs to be bled due to the point of engagement of the pedal, but would this really cause this kind of problem?
A chip is the next thing on the list, but I haven't made up my mind between APR, GIAC, and buying a used chipped ECU from the classifieds. Can a chip tuner safely change settings to make the engine wind up and wind down quicker?
Old Jun 20, 2009 | 05:02 PM
No that wouldn't be a clutch issue. Could be that the car is bogging down because its not making enough power. All the chip tuners tweak the throttle response, so you should see a difference even using a OTS tune.
Old Jun 20, 2009 | 05:23 PM
a2thy's Avatar
I planned on getting chipped anyway, so I'll see if that helps. I also have fault codes for post-cat O2 sensor and secondary air injection system, this wouldn't hinder acceleration though, would it?
Old Jun 22, 2009 | 07:34 PM
a2thy's Avatar
Bump.
