HP rating with testpipe, borla and giac
Old Mar 31, 2008 | 03:43 PM
  #31
A4speed's Avatar
Default RE: HP rating with testpipe, borla and giac
cool air = more power
with fmic you can adjust your timing and up your boost like cincy said so yes you will gain power.
and it will look cool
Old Mar 31, 2008 | 03:45 PM
  #32
cincyTT's Avatar
I'm make believe
ORIGINAL: B5 owns
But if I run like 18ish.. would a fmic help at all? I want one but I dont wanna get it just for the looks.. also, can you get around the secondary air injection pump or do you always have to remove it?
You are still heatsoaking the tiny core and it having plastic end tanks dont help. You dont have to remove it, just move it. If you dont want to mess with this stuff, you can always upgradewith a smic from tyrolsport or the one at 034motorsport. Much less work and more than enough cooling for a stock to 28rs turbo
Old Mar 31, 2008 | 04:31 PM
  #33
B5 owns's Avatar
Im fine with the work, its not really that complicated, just making sure that it will even help out the performance.
Old Mar 31, 2008 | 04:37 PM
  #34
cincyTT's Avatar
I'm make believe
you will see a gain in higher rpms where the temps really jump and it will be constant since the core wont heatsoak like the stock ic
Old Apr 1, 2008 | 10:32 AM
  #35
sirfalconx's Avatar
I remember reading somewhere that with the turbo ripped out, the 1.8T was aprox 95HP so every 14.7PSI will double that. I have raced my friends stock STi and it is a bit faster, but not much. Im running 19psi, but have other mods too.
Remember the 300hp is what the manufacturer is rating the STi motor at the crank with NO accessories, its probably closer to 285-290 at the crank with all the drive belts added on, a/c compressor/alternator/power stering, etc.. then knock off the powertrain loss and you really only need about 250 at the wheels to be on par with an STi. They are almost the same weight too.
Also dont forget sti is 6 speed for track racing, 6 speed doesnt help for straight line races, thats why the evo was a 5 speed, its less shifts =more time in gear.
Old Apr 1, 2008 | 01:31 PM
  #36
cincyTT's Avatar
I'm make believe
ORIGINAL: sirfalconx
FLAWED. 7psi on a ko3 is nowhere near the same as 7psi on a gt35r.
The base hp of the NA 20v is 110 or 120hp. It runs basically the same motor but with cams suited for NA. Think compression may be 10:1.
jjcrt2
Jan 2, 2009 09:23 PM
candycane84
Jan 11, 2008 01:13 PM
xcossx
Aug 3, 2007 07:11 PM
chitownA4
May 7, 2007 11:36 PM
texasboy21
Apr 3, 2007 10:37 AM
