I found the problem, now I have questions!
Old Jul 5, 2010 | 01:04 PM
PGRokhead's Avatar
Default I found the problem, now I have questions!
ok I just pulled the stock turbo on my 2000 1.8 A4. The shaft was snapped, the impeller ate the intake scroll and made lots of aluminum powder in the entire intake tract, the exhaust turbine got destroyed, turbo main bearing cracked in half. I'm thinking a stock ko3 replacement just to make sure the car runs ok before dumping $$$into aftermarket upgrades. I also want to know about all the extra plumbing withthis car's turbo....I'm a diesel guy and it seems that there is a serious amount of emissions stuff witht this car. We don't have emissions here, is there a "of Road Configutration" that I can put this thing back together with to avoid all the crazy hoses? Thanks for any help, I just want to get this car running to see if it's worth making into a play car.
B
Old Jul 5, 2010 | 06:59 PM
turbo kraut's Avatar
Tech Guru
there is a vac diagram on az you can follow..... i would look for a used k03 on the forums or there is a guy with a cracked housing he might just give you.....
to remove the old turbo is like making a sandwich easy
bennybiggs
Feb 11, 2009 12:19 AM
cooleststan
Jul 31, 2007 12:06 AM
JohnnyBravoA4
Jan 12, 2007 08:17 PM
tddk
Aug 23, 2006 01:20 AM
david9999
Jul 5, 2005 01:36 AM
