I got 4 Codes and Car Isn't Starting - Help!!
Old Feb 20, 2009 | 04:57 PM
Dylan19's Avatar
Originally Posted by brrman
Like auditech said, the P1127 is your offender and the rest are likely residual symptoms.
Turbo underboost usually = leak. You're losing air and sending too much fuel in your mix. Check all the hoses you can for cracks and splits. And make sure nothing has come loose.
All of my hoses have been checked. My Audi dealership could not fit me in today so i will be dropping my car off on Monday.
Originally Posted by cjzerocool
So I need to check it out thoroughly for vacuum leaks and fix any and all. Get new plugs for the cylinders.
I was thinking I would have my guy disconnect the catalytic converter so i could try starting the car without it possibly killing the engine. Cause if it runs without it connect and does with it connected than it may be that the cat is bad too.
does this sound ok?
I dont know much about the cat but one of the first things i did was order some spark plugs. the old ones werent necessarily bad but i replaced them anyways since bought and had them delivered before i looked at the old ones.
Old Feb 21, 2009 | 10:44 PM
cjzerocool's Avatar
Is it possible the engine could be bad and need to be replaced if these are the only codes coming up?
Old Feb 22, 2009 | 10:25 AM
Interceptor's Avatar
It sounds like some leaks but after what you said about your turbo glowing red hot you might be looking at a new one .
GeneralChaoss
May 4, 2015 03:02 AM
Graftly1
Aug 20, 2010 10:17 AM
rawdney88
Jun 16, 2010 05:59 PM
AutoUnionFan
Nov 17, 2008 01:26 PM
hollisterrobsta
Oct 24, 2006 03:03 AM
