I got problems!!
Old Feb 28, 2008 | 09:17 PM
BLK_A4's Avatar
Default I got problems!!
Ok first i noticed that when i rev up my engin. and then let of the gas the RPMs hover for like 2 seconds and then drops. Second i am eating threw break fluid!!! I filled it up like a week ago and now its empty again. I have no leaks or anything. Would putting DOT 3 break fluid cause this?
Old Feb 28, 2008 | 09:31 PM
CIA's Avatar
CIA
Default RE: I got problems!!
i dont think the liquid has evaporated over the last week.
Since when do you lose break liquid?? I seriously think you may have a leak somewhere.
Old Feb 28, 2008 | 09:32 PM
hiwords's Avatar
well our cars can take 3 or 4 but i really think you have a leak. there's absolutely no way break fluid can evaporate that quickly. go to ebay and buy this http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
this stuff is rly good. check all the lines and also check your clutch slave cylinder.
Old Feb 28, 2008 | 10:00 PM
mr.cAp's Avatar
check under the rear wheel wells, it might be spraying from the rear breaks. don't ask why but my jeep did the same thing, i would loose break fluid like crazy, and there were no visible leaks.
Old Feb 28, 2008 | 10:30 PM
ImTheDevil's Avatar
Could be losing it through the clutch system too - if I remember reading correctly (and seeing as how I only have one reservoir on my manual transmission A4), the clutch and brake systems share a reservoir. Therefore, either system could be the cause of the problem that is draining your fluid.
Old Feb 29, 2008 | 12:06 AM
eurodynasty's Avatar
isn't the reason your revs hover because audis have rediculously heavy flywheels?
Old Feb 29, 2008 | 12:23 AM
cjh807's Avatar
i had that problem with my 97 a4 and it was the booster lost a seal and was sucking the brake fluid threw the vaccume line.... check the recalls too cuz mine got recalled!!!
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
