Instrument cluster question
Old Feb 25, 2012 | 11:24 PM
mtp9's Avatar
Default Instrument cluster question
Trying to fix the LCD screen in my A4 B5. Have the part, know how to solder, but just can't for the life of me figure out how to open up the instrument cluster without thinking I'll break it. Help please?
Old Feb 26, 2012 | 02:51 AM
Cybersombosis's Avatar
The link in the Audi World DIY is broken for dismantling the cluster so here is another link to a working copy. It tels you all you need to know on how to take it apart. The only thing that is a little confusing is the side tabs. You have to cut your shims a little thinner in order to release the tabs. Good luck.
http://www.vaglinks.com/Docs/Audi/B5...auge_Strat.pdf
Doug
Old Feb 26, 2012 | 08:53 AM
jonbonesjones's Avatar
Moderator
its easier then that makes it seem.
two screw in bottom corners. just lift a tab with your finger and pull the case out enough so it doesn't re-catch and go around the cluster.
Old Feb 26, 2012 | 09:32 AM
jcA4Quattro's Avatar
i must have removed and taking my cluster apart 7 times yesterday to readjust the mph, had someone tape over some cel lights!! &@*#ers!!
Old Feb 26, 2012 | 12:13 PM
mtp9's Avatar
Thanks for the info! Got it. Didn't know the two screws in the middle of the cluster were it.
Old Feb 26, 2012 | 12:36 PM
could be differant with the 2000 model but my 98 has it on the sides.
heisse_mkII
Feb 23, 2012 07:20 PM
gravity73
Dec 1, 2010 04:22 PM
makav3li
B7 Models
Apr 26, 2010 11:57 PM
mikes_tt
Sep 22, 2008 10:56 PM
jrward
Nov 16, 2007 03:34 AM
