Intake
Old Nov 18, 2015 | 05:01 PM
nano619er's Avatar
Default Intake
Have a 99 audi a4 1.8t quattro looking to buy intake any suggestions on were I could purchase one called different places result of being discontinued for this model.
Old Nov 18, 2015 | 07:11 PM
MetalMan's Avatar
Welcome!
What are you goals with an intake? Generally speaking the stock intake is just as good as anything else up to almost 300whp. They make reusable dry (or oiled) filters for the stock airbox as well.
IMO only reason to go with an aftermarket intake is appearance and/or sound. In some cases just throwing on a cone filter, which is what many aftermarket intakes consist of, may actually hurt performance, since they are susceptible to intaking hot air due to proximity to the turbocharger.
Do a search for the Carbonio intake. It's expensive ($300+) but is one of the few that won't hurt performance compared to a stock air box.
Personally I run the stock air box with a full heat shield, even with an upgraded turbocharger.
Old Nov 18, 2015 | 07:45 PM
nano619er's Avatar
Originally Posted by MetalMan
Welcome!
Thanks for the reply I'll just hold off on that maybe upgrade D/V what do u recommend I was looking at a forge 008 or 710n. Also have a rca port n wire with push button connected to ecu what would that be for?
Old Nov 19, 2015 | 08:03 AM
A4TurboGuy's Avatar
I have a high flow drop in and a billet diverter valve. That works just fine for me and I'm pushing 17+ psi.
IMHO, I agree with MetalMan. The stock piping is designed to be the best option for the car and the performance and reliability of the system back that claim up.
Like I said: A drop-in w/a diverter valve should be all you need.
Benefits: Cheapest, most effective and most efficient mod.
G/L
Old Nov 19, 2015 | 10:08 AM
nano619er's Avatar
G/L
Old Nov 20, 2015 | 09:26 AM
A4TurboGuy's Avatar
My pleasure.
The ECU "port button" might mean that your car has been tuned and that is some sort of "on/off" feature.
Here you go:
Black Recirculate Diverter Valve Turbo BOV Boost Bypass Fit VW Audi 1 8T 2 7T | eBay
The cheapest all Aluminum, anodized DV you'll find.
Old Nov 20, 2015 | 09:32 AM
nano619er's Avatar
My pleasure.
Here you go:
Thanks u
Old Nov 21, 2015 | 10:01 AM
A4TurboGuy's Avatar
My pleasure.
Old Nov 21, 2015 | 11:15 PM
joenelson7687's Avatar
I second the carbonio. I also did pipe upgrades with my intake and i noticed a little more umph in the lower end
Old Nov 22, 2015 | 11:26 AM
A4TurboGuy's Avatar
I replaced my stock muffler with a normal sized Stainless muffler (not a grapefruit shooter) just for the looks. I kept everything in between stock (IE the cats and resonator).
It gives the car an updated, classier look, while adding power w/o adding (a noticeable amount of) noise.
David Narez
Jun 26, 2013 09:20 AM
lukestaah
Jul 28, 2012 11:26 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
apg96
Jun 28, 2005 05:34 AM
