Is The Intake Snorkel Necessary?
Old Jan 15, 2013 | 07:59 PM
george1546's Avatar
Default Is The Intake Snorkel Necessary?
Hey people,
I'm curious whether or not I can run without an intake snorkel?
I have an aftermarket heat shield which looks awsom and the snorkel simply likes like crap with the heat shield. I know the snorkel takes in cold air but how much of a difference would their be without one?
Old Jan 15, 2013 | 08:08 PM
ImTheDevil's Avatar
Zero difference. You're sucking up hot air with or without a snorkel, with or without the heat shield.
Old Jan 15, 2013 | 08:11 PM
george1546's Avatar
Thanks for that, I will get rid of that snorkel immediately.
Old Jan 15, 2013 | 08:20 PM
george1546's Avatar
Ill leave it like this so some cold air makes its way, ignore the boost gauge line, I will clean that up.
Old Jan 15, 2013 | 08:28 PM
ImTheDevil's Avatar
The "cold" air mixes with ambient underhood (read: hot) air, then gets superheated by the turbocharger that is compressing it inside a multi-hundred-degree metal housing. The snorkel trying to funnel in outside air will do zip-point-**** for cooling the intake charge and increasing its oxygen density. A better, more-efficient bar/plate style intercooler and a water/meth injection system will do FAR more to fend off detonation and allow higher/safer boost-timing combinations.
David Narez
Jun 26, 2013 09:20 AM
deftoneskevin
May 7, 2013 08:35 PM
willie7182
Jan 1, 2011 10:45 PM
n7plus1
Mar 16, 2009 11:00 PM
