Interchangeable Abs Modules?
Old Oct 9, 2011 | 10:02 PM
ericp1.8T's Avatar
Default Interchangeable Abs Modules?
Just wanted to let you guys know, I went to the junkyard and found a module that looked just like mine. So I paid the $25 and got it. My Abs light has been on and the brake light has been blinking for the longest time. I decided I'd try hooking up this new module even tho the numbers didn't match. Well, my ABS light is still on, but the blinking brake light turned off! I don't have a vagcom so I haven't tried turning the light off yet. Once I get it hooked up to a vagcom I'll let you guys know the result and the part #s..
Old Oct 9, 2011 | 11:44 PM
MetalMan's Avatar
In my experience there is no compatibility between ABS units with different part numbers. And you need VAG-COM to find the fault code.
With the ABS system once the cause of the fault is fixed the light will turn off automatically. VAG-COM can't turn it off.
Ricston
Mar 23, 2014 08:11 AM
markymarc
Sep 18, 2010 05:39 PM
outlaw24
Dec 16, 2008 08:03 PM
KTwo
Nov 1, 2008 03:52 PM
jude14601
Apr 23, 2008 12:07 PM
