Intercooler Leak??
Old Feb 23, 2008 | 12:58 PM
hartsoe1's Avatar
Default Intercooler Leak??
[:@]Still chasing the boost/vac leak. Did the pressure test with the PVC fitting at the airbox and have a small leak in the IC area. I removed and reseated the IC inlet and outlet hoses and clamped the hose clamps tighly. Hoses looked ok but didn't replace. Still have the little leak sound. Is there anywhere to leak over there? can the MAP fitting leak? Otherwise it is the IC. There was a little (teaspoon?) bit of oil in the IC inlet pipe at the bottom, fyi. What are my options at this point if the IC has a leak?
thanks
Old Feb 23, 2008 | 01:12 PM
cjh807's Avatar
Default RE: Intercooler Leak??
not to sure about the leak but the oil in the turbo system and ic is normal
and if it is the ic your best bet is to replace it :/
Octane567
Aug 8, 2014 10:28 AM
LilGman81
B7 Models
Feb 25, 2013 06:02 PM
inventorA6
Apr 15, 2009 06:46 AM
morph
Jan 8, 2008 10:16 AM
