Intermediate shaft Seal Replace
Old Jun 28, 2011 | 10:29 PM
mtnxtreme's Avatar
Default Intermediate shaft Seal Replace
Doing my timing belt and removed the intermediate shaft plate to replace the O ring and seal. Just curious if the cam, crank and intermediate is the same seal, because that is what RAI sent me. Also I pulled it out a few inches thought I would clean it, won't come out all the way, I lined up my keyway with one of the bolts before I pulled it out, then re-lined it when I pushed it back in, just wanna make sure I did'nt mess anything up , I read somewhere this shaft runs the oil pump, is there any way i could have broken something or not pushed it back in, just wanna make sure before I put it all back together.
Old Jul 12, 2011 | 07:47 AM
mtnxtreme's Avatar
OK in case this might help someone else, if you pull it out and push it back in it will not hurt anything, the guys at RAI told me the shaft has teeth at the back and will mesh back in, and all 3 seals are the same, but don't forget the intermediate has that extra O-ring on it.
JasonDillard
Nov 2, 2013 05:53 PM
savantv
Dec 30, 2012 01:51 AM
Crl2252
Nov 8, 2009 04:38 PM
gsacoman
Aug 5, 2008 12:01 PM
shovin
Mar 14, 2007 07:03 PM
