Latest project on the car (pics)
Old Mar 16, 2008 | 11:48 AM
jiggleo's Avatar
Default RE: Latest project on the car (pics)
Looks good man. I'n not sure I need the extra attention from the dark lights or I would do that myself.
Old Mar 16, 2008 | 09:40 PM
30vQuattro's Avatar
they look pretty good, i would of just tinted the reverse part though, i think that would give it the "euro look" btw, what is the dual raer fog mod? you can do that ? how?
Old Mar 16, 2008 | 09:53 PM
kolbs_91's Avatar
Looks really good, man. I've been considering doing this to my car, but I don't want it nearly as dark as that. I want smoked, but still relatively stock looking, if that makes sense.
How dark were they looking after one coat??
Old Mar 16, 2008 | 11:41 PM
ImTheDevil's Avatar
kolbs_91: I know what you mean. The first coat was done very lightly to just give a base for the ensuing coats to grab onto. The first coat has to be done lightly, especially if you don't sand the lights, which I didn't do. If you want only a slight smoke, I'd do one coat on top of that, maybe a second light/fast coat afterward. The good thing is, you can reinstall the lights after about 30 minutes of drying time, since they'll be dry enough by then to move around and you can reinstall them without touching the lens. You could try it that way, and reposition them on the car after each coat until you get the desired darkness. I took a drive tonight and surprisingly, despite how dark they look, the taillights shine through very well, and the fogs are even brighter - the level of tinting I did didn't seem to block much light output at all.
30vQuattro: I'm not sure how that look would work out for me. If I did any partial tinting, I'd have left the clear reverse lens untinted and just tinted the red, but that's simply personal preference. As for the dual rear fog mod - it'll take about 5 minutes. The bulb trees behind each taillight have sockets and full powered wiring for rear fogs on each side, but only the driver's side has the required opening in the back of the housing for the bulb to go through. On my car, on the passenger side where the rear fog would be, there was only a narrow rectangular opening. I simply drilled it out with a dremel until a bulb would fit through. I bought a bulb to go into the fog socket on the passenger side tree, popped it in, and I was done. Power is already sent to the socket, so all you have to do is put a bulb in it and open up the slot in the housing to allow the bulb to pass through, and you're done.
Old Mar 16, 2008 | 11:45 PM
A4speed's Avatar
I like the look a lot!
Old Mar 16, 2008 | 11:48 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: kolbs_91
when you getting down here again?
we can do them then
Old Mar 16, 2008 | 11:57 PM
feerocknok's Avatar
Stock is candy apple red, one coat of tint is bloody red, three coats is murder blood, four coats is black, five coats is BLACK.
Old Mar 17, 2008 | 12:12 AM
  #18
cincyTT's Avatar
I'm make believe
LED lights are brighter.
Old Mar 17, 2008 | 12:15 AM
  #19
ImTheDevil's Avatar
I've thought about those some - not sure if I need them though. The lights appeared plenty bright tonight.
Old Mar 17, 2008 | 02:02 AM
  #20
Quattro_1.8t's Avatar
looks alright, I'd rather tint around the reverse lights for a better look IMO
