launching.......
Old Aug 13, 2010 | 12:59 AM
pbrules10's Avatar
Default launching.......
I have an 01 a4 1.8tqm. I'm not one to race much or be an aggresive driver but sometimes me and my friends will play around from light to light and whatnot. I have always been afraid to launch because I don't want to mess anything up. If I try to launch everyonce in a while is there a risk of damaging anything? My friend says I should be using the awd to my advantage of launching but I'm just worried about breaking something. What do you think?
Old Aug 13, 2010 | 01:19 AM
joenelson7687's Avatar
Well, the more rough you are with your car, the quicker you will wear parts down. Is doing a 3500rpm launch going to kill your car, probably not. But you should be aware that doing things like that will wear your clutch faster. If you want to do things like that, upgrade to parts that can take some abuse, ya know? But to answer your question, you car will not fall apart from a couple launches. I just wouldn't go too much until you upgrade your stuff.
Old Aug 13, 2010 | 01:45 AM
Mike-2ptzero's Avatar
If you are on a stock clutch dont expect it to last or even hold up very long. If you want to take some stress off the clutch pump your tires up to 45psi before trying to launch it. 3500 isn't really going to be high enough to launch it hard with a K03, to do taht you will need to be up in the 4k-4500 rpms.
Old Aug 13, 2010 | 02:10 AM
pbrules10's Avatar
Thanks guys I'm not looking to do any crazy hard launches just something to give me a good start against my friends 328i
Old Aug 13, 2010 | 02:44 AM
If you dont launch hard you will just end up bogging the car.
Old Aug 13, 2010 | 02:49 AM
shhmaudi's Avatar
Yup^^ gotta spool the turbo a bit.. I usually blip the throttle and get to around 45 and then sorta gently dump the clutch.. Right before the point where the clutch engages. If possible try to learn on a wet road to take some stress off of you AWD
Old Aug 13, 2010 | 10:15 AM
1. bring clutch up to just below the engagement point
2. blip the the throttle a few times to 4k
3. at the start of the upswing go WOT
4. release clutch all at 1 time as you get to 4k-4500
5. be ready to shift to 2nd gear because 1st will go in a heart beat
devin3592
B8 Models
Apr 9, 2014 10:21 AM
Built2crash
B8 Models
Feb 25, 2013 03:35 PM
deek
Apr 16, 2007 04:42 AM
Deb38
Jan 6, 2007 09:35 PM
Audinam
Apr 17, 2006 05:33 PM
