MAF Question
Old Jun 17, 2016 | 07:55 PM
AvantSLine's Avatar
Default MAF Question
So I've been chasing down a "ghost in the machine" and I now suspect it is possibly a MAF issue.
2001 A4 2.8L
I checked voltage and continuity at the MAF harness plug. Pins 1 + 2
I get 5v...which I suspect is proper as voltage ranges are from 5-12 normally. If it is supposed to be 12v, then this could be my problem and not the MAF
Anyway, plugging the harness back in and firing the engine, I get a constant reading of 5v with no fluctuation....even slightly revving the engine there is no change.
IF, 5v is proper to the MAF, is the non reading of any fluctuation at idle or revving an indication that the MAF is toast? Or does it sound like I have a low voltage to the MAF issue not allowing it to actually function?
I'd checked the Bentley manual and it states to check the MAF fuse, but could not find a chart where the fuse is.
ADDED:Found the wiring diagram in the Bentley manual on page Y650. Notation: D22 "Connector (over fuse 234), in wiring harness front, right". Is this an in line non replaceable fuse? (Haven't located it yet)
Car is in good shape and well maintained and no wire hacking, so the harnesses and grounds should be OK. Maybe a ground issue?
Any help would be appreciated!
Loquito14
Oct 4, 2016 09:07 AM
ILoveT
Feb 8, 2013 08:50 PM
audia4x4
Apr 17, 2010 11:47 PM
gripspec
Apr 18, 2009 10:29 AM
JCatt9
Jun 9, 2007 03:45 PM
