Mild humming
I'm getting a mild humming sound while driving, (like offroad tires on the highway) I think it's coming from the rear. I'm thinking wheel bearing. But hoping it's something easier to repair. Any ideas as to what the sound could be?
Swap tires front to rear first. If you have an alignment issue it could be feathering the tires and creating road noise. If the sound stays in the rear jack it up and shake the wheels. If there's any play it's a bad bearing.
Honestly, it's loudest when I'm slowing down(5mph) you hear it at all speeds but when you slow down it gets deeper and when you speed up it gets higher. It really sounds like igot mud terrain tires on. I'll Jack up the car today and get a better look. Is it safe to Jack the car up on the rear diff? It's easier to put stands under it that way hut I wasn't sure.
I jacked up the car and grabbed the wheel at 9 and 3 and tried to rock it and it had a little play. Not much. I'm guessing wheel bearings are the culprit. Where is the best place to get new ones at?
