Mild humming
Old May 11, 2010 | 12:29 AM
QuattroNW's Avatar
Default Mild humming
I'm getting a mild humming sound while driving, (like offroad tires on the highway) I think it's coming from the rear. I'm thinking wheel bearing. But hoping it's something easier to repair. Any ideas as to what the sound could be?
Old May 11, 2010 | 11:19 AM
briesa4's Avatar
The most common thing is the wheel beering I just had to do all four recently its not that bad
Old May 11, 2010 | 12:46 PM
jiggleo's Avatar
yep wheel bearing
Old May 11, 2010 | 01:21 PM
ImTheDevil's Avatar
Swap tires front to rear first. If you have an alignment issue it could be feathering the tires and creating road noise. If the sound stays in the rear jack it up and shake the wheels. If there's any play it's a bad bearing.
Old May 11, 2010 | 01:36 PM
A4speed's Avatar
most likely bearings, especially if it gets louder as your going faster.
Old May 12, 2010 | 01:24 PM
QuattroNW's Avatar
Honestly, it's loudest when I'm slowing down(5mph) you hear it at all speeds but when you slow down it gets deeper and when you speed up it gets higher. It really sounds like igot mud terrain tires on. I'll Jack up the car today and get a better look. Is it safe to Jack the car up on the rear diff? It's easier to put stands under it that way hut I wasn't sure.
Old May 14, 2010 | 09:39 PM
jiggleo's Avatar
It's not recommended on any vehicle but I couldn't tell you all the times I've done it and I've never had it be an issue.
Old May 15, 2010 | 02:59 AM
QuattroNW's Avatar
I jacked up the car and grabbed the wheel at 9 and 3 and tried to rock it and it had a little play. Not much. I'm guessing wheel bearings are the culprit. Where is the best place to get new ones at?
Old May 15, 2010 | 08:19 PM
lolo22's Avatar
I got the same noise, I was gonna post a thread but couldnt think of a way to describe the sound.
jbh2403
Jan 21, 2012 12:55 PM
stitanium
B7 Models
Aug 27, 2010 02:49 PM
dylsaudi
Dec 17, 2008 11:21 PM
dylsaudi
Dec 16, 2008 07:22 PM
eurokid
Nov 30, 2006 04:47 PM
