Most boost throught stock a4
Old Aug 25, 2008 | 05:14 PM
slew87's Avatar
Default Most boost throught stock a4
I was just wondering how much boost i can put through a stock 1999.5 audi a4 1.8t. I know that they have about 8psi stock but i was wondering what the limits are on it that I can do safely before i need to start upgrading. Thanks
Old Aug 25, 2008 | 05:24 PM
Jc61990's Avatar
i think if u chip your ecu you get around 15psi
Old Aug 25, 2008 | 06:44 PM
slew87's Avatar
yea but im talking if i dont chip it and only use a boost controller. Untill i can get the money for the chip
Old Aug 25, 2008 | 11:04 PM
ghost6303's Avatar
if you go above 14psi (1bar) with no chip you get put into limp mode automaticly, which cuts the boost to 5psi untill you reset your ecu. i know cincytt manged to get over 20 psi with no chip, so he can chime in on exactly how. im sure it required alot of tweaking and probably programming stuff with vagcom. but with a chip you can get 20-22psi with a very crappy powerband by turning up your MBC. thats about the limit with a k03. anything over 20psi and you are really pushing the turbo to its limits.
Old Aug 25, 2008 | 11:24 PM
Jc61990's Avatar
isnt what he did was the diode thing that only works on like 00and up
Old Aug 25, 2008 | 11:37 PM
ghost6303's Avatar
possibly- i didnt know what year the car was, just that it was a B5. well if your car is 1999 and below, 14psi is your limit unless you want to reprogram your ECU with vagcom or find a way to keep your car from finding out your running more then 14psi. but if you do that your going to have to adjust your fuel injection times, ignition timing and other things to make your car not run lean and explode under that much boost.
Old Aug 25, 2008 | 11:44 PM
Jc61990's Avatar
yea, its probly safer to just chip it, its 249$ for a SpeedTuning Chip thats what im getting
http://www.speedtuningusa.com/products/audi.htm
MK1audiTT
Apr 21, 2008 05:26 PM
mickey3c
Nov 27, 2006 01:15 AM
turbo
May 1, 2006 10:23 AM
kathan21
Oct 2, 2004 12:09 AM
