Motor removal/Front clip removal
Old Nov 18, 2010 | 07:46 PM
  #41
99a4wagon's Avatar
Originally Posted by FasterA4ThanUrs
I gotcha. I think your getting confused because awd DSMs have big transfer cases with halfshafts that do just slide out. You're going to find that 1.8ts are far easier than what your used to. Our trans have internal t-cases and with the front clip off, everything is right there with plenty of room to work. I'll pm you my number now.
Ahh motor is out thank god. Now I have to wait for my pilot shaft bearing to come in. It was a pain because theirs so much small stuff hooked to the motor.
I have to put the wiring harness on my other motor. I also have to swap flywheels because that motor was from an automatic. Why type of bolts hold the flywheel on so I can go pick a set of sockets up like that?
Old Nov 18, 2010 | 08:22 PM
  #42
FASTER's Avatar
Tech Slut
Oh boy, the flange on the crank will not be compatible with a flywheel. I believe an auto crank can be machined to fit the flywheel, but I'm not positive. But flywheel bolts are like 17s or 19s iirc. If you don't have an impact then you need to use 2 breaker bars so it won't just spin
Old Nov 19, 2010 | 12:27 AM
  #43
99a4wagon's Avatar
So I got the wrong motor? That ******* told me it would bolt right up. Just have to change the flywheel.
Old Dec 4, 2010 | 08:33 AM
  #44
workoncars's Avatar
I just ran into the same issue with the flywheel not fitting on an auto engine I am installing. Can the flywheel be modified or is the crank the only way to fix this? It would have been nice to know this when I bought the motor. crap!
Old Dec 5, 2010 | 03:06 AM
  #45
99a4wagon's Avatar
Does your flywheel fit on the crank at all?
Old Dec 5, 2010 | 10:10 AM
  #46
workoncars's Avatar
The od is the same, but it sticks out too far and the id is not large enough for the pilot bearing to fit in. I am swapping out a 96 2.8l. No one asked auto or manual so I guess I am a little lost on this one? I already returned the old engine for the core charge so I can't see what that was like. Maybe I will stop by and see if they have it sitting around.
Old Dec 5, 2010 | 01:44 PM
  #47
99a4wagon's Avatar
Take a pic and post it up u said it sticks out to far. I want to see this. My flywheel seemed to fit fine over my crank.
Old Dec 6, 2010 | 07:21 PM
  #48
99a4wagon's Avatar
Ok or don't.
Old Dec 6, 2010 | 10:01 PM
  #49
workoncars's Avatar
It's 20 deg. out side, and I didn't feel like going out to the barn tonight. I will get some pics. I want to stop buy where I bought the motor and get some more info too.
Old Dec 6, 2010 | 11:44 PM
  #50
99a4wagon's Avatar
I didnt need to shaved anything just order that spec pilot bearing.
