my 2.8 has tooo many problems.
ive noticed for like the past week, my car has been idling low.
maybe im being paranoid....i d k. maybe it has to do with my oil leak??
when i start her up, it goes up... then down to like one notch below 1000rpms,
is that normal??
damn, i need to get my car checked out!!!!
cause thatt oil leak isnt the only problem i have right now.
anyone ever have this happen to them???
is that normal??
What year is the car? You need to make a signature on your profile page that includes your year, drivetrain, engine, transmission, etc (ie, 99 2.8qm for a quattro manual of that year and engine). It helps in this case. If your car is a 30v (98 or newer), you have a secondary air pump. When you cold start the car the pump is on and your RPM are around 1200, and when the pump kicks off, the revs drop. If you have a 30v, then your car's behavior is normal.
Knowing the car's information can also help in diagnosing your oil leak if you want to do that.
Smokin Tubes
Feb 5, 2012 10:11 AM
commedecargons
Nov 9, 2005 06:43 PM
