My A4 is taking on water....HELP!!
Old Jun 12, 2013 | 09:30 PM
AngusA2_A4's Avatar
Default My A4 is taking on water....HELP!!
Hello Everyone!
I was hoping for some help. My 2000 A4 has developed a leak of some sort so that water accumulates in the rear passenger footwell after a hard rain. The water accumulation is most evident when I park on my driveway, which has a considerable incline.
I searched google and watched some video on how to clear the drains in front of the firewall. They were filled with tons of decomposing leaves, etc. I removed all that junk, tested the drains, and they seemed to work fine. I was looking forward to the next rainfall!
As it turns out, my hopes were dashed. Last week, we had a downpour and when I got into my car to go to work, there was almost 2 inches of standing water in the rear passenger footwell again.
I then looked at the sunroof drains, and was able to thread a weedwacker cord through the front drains. I tested them and the water flowed freely out of the outlets near the front door hinges.
I have not had a chance to check the rear drains, since it neccessitates removing the rear bumper, something I am not really looking forward to.
Is there something I am missing? Is there any other thing I can check? I am afraid of the damage that continued moisture might do to my floor pan, carpet, and the passenger seat assembly.
Sorry this is so long. I appreciate reading this far!
Thanks!
Old Jun 13, 2013 | 01:46 PM
cnigro1279's Avatar
You don't have to pull the bumper. I was able to peel back my trunk liner and pull the tubes straight out of the fender, grommet and all. Then pop them back in place when you're done.
Old Jun 13, 2013 | 05:07 PM
AngusA2_A4's Avatar
Default Gracias!
I will give that a try first! Thanks!
Old Jun 13, 2013 | 11:51 PM
inspecta gadget's Avatar
I had a leak and it killed my driverside seat sliding motor. that motivated me to find it. so get a partner with a waterhose and soak areas of the car for 5-10 minutes where you are looking. and you will find it. The leak is probably coming from one of those grommets up under your cowl
Old Jun 14, 2013 | 08:47 AM
CCA4's Avatar
There is a standing TSB on this, if you take your car to a dealership they will clean the drains for you for free.
Old Feb 5, 2018 | 04:26 PM
BookmarkA4's Avatar
Default Rainwater in rear footwell problem
I have a '99 A4 Avant and have the problem of rainwater collecting in a large puddle in the rear left side passenger footwell - front passenger is dry, so far! Firstly, my A4 doesn't have a sunroof, secondly the drainage ducts at the front of the car have been cleared, thirdly - we've tried the 'playing a hose over the car' trick but nothing could be detected. Is the rainwater getting in behind some panelling? Anyone got any ideas?
Mark, Sidmouth, UK
Old Feb 5, 2018 | 05:33 PM
elduderino200's Avatar
Could it be a clogged heater core? How's your heat working?
gilliethakidd
Feb 15, 2012 06:06 PM
krystallbluea4
Jan 3, 2009 01:44 PM
greenmonty
Jul 24, 2008 07:40 PM
eliTTe
May 14, 2007 03:25 PM
