My Update Thread! adam044
Yeah I love the GoPro. Trying to use it more. Recently got the LCD touch screen for it.
I guess it's time to replace my ECT sensor. Hasn't gone off for about 3 weeks now, I was hoping it was going to but I guess not. Where is the best/cheapest place to get the part? I prefer OEM.
Replaced my CTS today. Easy job once I found out where it was. Forgot my common sense today though because as I pulled out the sensor I was greated with a splash of coolant. Never released the pressure from the tank, really had no idea I had to. I will be stopping by my mechanic tomorrow though as now my coolant is below the MIN line.
Engine light was still on when I started the car after I replaced it. Guessing I just need to have it cleared by autozone or similar store.
Oh? I have some ideas.
- Replace the coolant expansion tank
- Remove that sticker on the driver's shock tower
- Clean the dirt off the intake manifold and throttle body
- Trace the outline of the fluid tank cap's logos in silver
- I see two small brown spots by the left shock tower bolt, maybe dirt
- Replace all of the visible fasters with stainless steel
- The throttle body hose clamp looks a corroded
- That grommet below the hard fuel lines could be cut out and plugged with a piece of delrin bar
- You could replace the old spring style hose clamps with stainless worm clamps
- If you really wanted to get into it you could file down all the casting marks on the intake manifold, smooth it out, and bead blast/paint/powder coat.
Now if only you posted links for the things you suggested...
The result:
