New Owner Needs Help
Old Oct 4, 2014 | 03:28 PM
zdods's Avatar
Default New Owner Needs Help
Hey yall, just traded for an 01 a4 avant and have a few questions. First what is the box bolted to the top of the rack that holds the 6 disk changer? 2nd what is the vaccum hose pictured below? and third what do these wires go to in the second and third pic they are a white and a yellow. thanks for the help im gonna go try to find my coolant leak.
Old Oct 4, 2014 | 03:31 PM
zdods's Avatar
here are pics
Attached Thumbnails New Owner Needs Help-20141004_142221.jpg   New Owner Needs Help-20141004_142247.jpg   New Owner Needs Help-20141004_142255.jpg
Old Oct 4, 2014 | 03:53 PM
mtroxel's Avatar
The vacuum hose goes to the accumulator in the left front fender. It's a blue plastic bottle that is shaped a bit like 3 *****. With that vacuum hose going nowhere, you have a big vacuum leak.
Not sure on the wires down front, but given that location I would guess they go to the ambient air temperature sensor. It's supposed to sit down low at the bottom of the AC condenser on a plastic bracket. If your instrument cluster tells you the wrong temp, that's another reason to believe those wires go to that missing sensor.
Old Oct 4, 2014 | 05:33 PM
zdods's Avatar
Default agree
yeah I just got done pulling the front end apart and found where the vac line runs now just to get one....
I didnt find anything with wires ripped off and my out temp seems pretty close to right but who knows exactly.
I found a crack in my plastic thermostat housing, I think I can change it without pulling my t-belt, it was done not long before I got the car and they did the water pump with the t-belt. Do you know if it is feasible to yank that housing without pulling the t-belt( or acc pully on crank)
Old Oct 4, 2014 | 05:55 PM
zdods's Avatar
Default thermo housing
Is there a year that I could pull a thermo housing from that is metal that would fit my 2.8?
Old Oct 5, 2014 | 08:53 AM
mtroxel's Avatar
There are guys here who have done that. I tried it once and just ended up scarring the surface that presses against the gasket.
I believe the metal and plastic ones are interchangeable. My 99.5 has the metal one, don't know about the others.
Old Oct 7, 2014 | 09:42 PM
zdods's Avatar
thats good to know, I endued up using some epoxy repar putty on mine and it seems to be holding. Thanks for your help im sure I will be begging for more when I get my new exhaust leak taken care of, Im starting to not feel good about this trade
Old Oct 9, 2014 | 10:08 PM
zdods's Avatar
thanks for the help. I have put alot into this car but i just drove my old eclipse and this car is really alot better
zandrew
Oct 31, 2012 07:43 AM
CasopoliS
May 22, 2011 12:15 PM
richy
Dec 11, 2009 12:15 PM
cool_kyle_3000
Oct 4, 2006 04:46 PM
jomoma
Oct 24, 2005 11:45 PM
