New Turbo...New Problems
Old May 16, 2011 | 09:37 AM
browny355's Avatar
Default New Turbo...New Problems
I just put in a turbo last night and for the first time ever, I am getting boost. I have an issue when my car is boosting hard. It starts to stutter when Im on the gas and wont let me accelerate anymore. Also, random idiot lights in the dash go off when this happens. I originally thought bad coil, but no codes. What could this be?
Old May 16, 2011 | 02:40 PM
browny355's Avatar
update: Got some codes P1300 and a MAF sensor code. Changed out the sensor, still had issues. Then got the code for misfire on cylinder 4. I changed the coil and car runs a bit better. Still have random lights going off on the dash.
Old May 16, 2011 | 04:57 PM
Rollineuro's Avatar
Sounds like your plugs are gapped too big. Did you install a bigger turbo or up the boost? Seems just like when I chipped mine and left the plugs at .032. I got changed the gap to .028 and problem solved, never happened again.
Old May 16, 2011 | 10:23 PM
willie7182's Avatar
This is the exact problem I am having after installing a new turbo. I threw a code for too much boost. Still not sure what is wrong.
Old May 26, 2011 | 11:10 AM
browny355's Avatar
I'll try changing the plugs. My boost is all stock. K03 turbo. Never had it working since I bought it so I'm not sure if it happened on the last turbo. Here are the codes I got.
P0103 - MAF voltage too high
Misfires:
P0300
P0301
P0302
P0303
P0304
All coilpacks have been changed out.
Old May 26, 2011 | 01:20 PM
ImTheDevil's Avatar
What year is your car? You may have an ICM issue.
Old May 26, 2011 | 02:50 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Gotta be the ICM.
Old May 27, 2011 | 09:47 AM
browny355's Avatar
I thought about the ICM too. But I put in a new N75 valve that I had lying around last night and it fixed the problem. The solenoid must have been getting stuck.
2012audiA5
Jul 19, 2014 09:34 AM
Davey89
Feb 2, 2010 12:46 AM
dnhtaauditt
Oct 21, 2009 07:04 PM
mfryer1
Oct 12, 2007 02:39 PM
elway7uk
Sep 5, 2006 01:27 AM
