No pressure in my brake lines.
Old 07-24-2012, 07:15 PM
Raybbaby's Avatar
Default No pressure in my brake lines.
So, about 2 weeks ago I replaced my rear brakes. Pads, rotors and calipers. Bled 'em down, never bled the front lines though. Brakes were spongy, and I knew I needed to bleed them again. Now I'm trying to do that, (bleeding the lines) and there's no pressure. At all. I get some resistance on the first pump, but then the pedal goes to the floor, and it really just flops up and down after that, and when I have someone else pump them, I can open the bleeder nipple, and there is simply no pressure. No air, not even any fluid is pumped out. I don't get it. Any one else ever had anything like this?
Old 07-24-2012, 08:15 PM
jonbonesjones's Avatar
Moderator
make sure the resivor is full. bleed the rear brakes. open the front bleeder screws and pump the **** out of the pedal (keep eye on fluid) it might take a while but if theres no problems the fluid will come. After you get initial fluid close it and bleed normally. I usually bleed 2-3 times to make sure.
Old 07-24-2012, 10:01 PM
Dozanti's Avatar
You have to bleed these cars in reverse order unlike other cars. I knew I book marked this link for a reason and could use it one day ( https://www.audiforums.com/forum/b5-...-bleed-179802/ ). Try it and see if it helps !
Old 07-24-2012, 10:17 PM
bshusted's Avatar
As was previously mentioned, these cars seem to like to be bled in the reverse of the typical bleed.
I would also recommend building yourself a cheap power bleeder. It makes this job so easy for just one person to do. There is also less chance of introducing air into the lines. There are DIYs on
Old 07-24-2012, 11:40 PM
Raybbaby's Avatar
Yeah, I'm still stumped. reservoir is full, but even backing the bleeder screw all the way out, no fluid is coming through. Maybe an air lock of some kind?
Old 07-25-2012, 07:44 AM
Moderator
is this just one caliper your trying? or all 4 wont bleed? it took me a long time to get my brakes all to bleed correctly. I thought they were fucked somehow. Make sure no other bleeders are elft open other than the one your trying to bleed.
Old 07-25-2012, 10:43 AM
bshusted's Avatar
If you undo the hose at the caliper is there fluid coming through? Which wheel are you trying to bleed?
Old 07-25-2012, 12:05 PM
Raybbaby's Avatar
I'm not trying to bleed one wheel, but the whole system. One wheel at a time of course. I bet it is at the ABS pump at this point.
Old 07-25-2012, 12:11 PM
cnigro1279's Avatar
Default I Read somewhere...
That if the reservoir goes completely empty that you may need vag-com to bleed the ABS pump. Wondering if this is your problem.
Old 07-25-2012, 12:26 PM
Moderator
its damn near impossible to get air in the abs. I drained my system completely, and didn't have to bleed the ABS. I think he's just not bleeding enough.
Quick Reply: No pressure in my brake lines.
