No start issues
Old Oct 22, 2012 | 07:11 PM
bmoore98A4's Avatar
Default No start issues
Cam position sensor (G40)
MIL control circuit open or shrot to plus
Misfires on 1 and 3
I am just biting the bullet and replacing all coil packs plugs wires cam position sensor and a few intake lines. What the hell is the MIL lol
Is there something that would cause this to all happen at once? It drove yesterday, rough idle, hard start from cold but still ran well under load. (2nd A4 ive had)
Old Oct 22, 2012 | 07:34 PM
bmoore98A4's Avatar
Ironically its a 98 1.8t, forgot to add that for clarification lol
Old Oct 22, 2012 | 08:14 PM
ImTheDevil's Avatar
Your cam sensor is probably shot. The ECU needs verifiable signals during cranking from the cam and crank sensors or it won't start the car. On a V6, one cam sensor can fail and the car will still start since it can read the other. On a 1.8T if the cam or crank sensor is bad, the car can't correlate the bottom and top end rotational parts' positions and it won't allow the car to start.
Old Oct 22, 2012 | 08:26 PM
bmoore98A4's Avatar
with 150k, would it be a good idea to do the coil packs anyway? Or go by "if it aint broke, dont fix it."
Planning on having this car around for a long time so longvity is key. Hopefully she will be a track car in the future
Old Oct 22, 2012 | 08:48 PM
ImTheDevil's Avatar
You wouldn't hurt anything doing them but if the car was running fine before this issue, it's probably premature to get them. I'd buy one or two and put them in the trunk. That way when you do get coil death, you can change it on the spot and drive to the parts store to get the rest of them. Swap them all out then and keep the good ones you remove for backups.
Old Oct 23, 2012 | 07:04 PM
bmoore98A4's Avatar
good idea. on a side note, I couldnt get to service position one. This car has never been taken apart (150k on ORIGINAL timing belt.) Any words of wisdom on getting the plastic facia off? I dont want to break the plastic hangers and have it sag on me like other one...
roquevandress
May 31, 2014 07:55 AM
adegox
Nov 11, 2011 09:46 AM
Malbujb
B8 Models
Feb 7, 2011 01:58 PM
jusTina
Jul 16, 2009 12:14 AM
Bartlett
Nov 3, 2008 11:01 AM
