Noise when heater on
Old Feb 20, 2014 | 08:39 AM
kozhouse's Avatar
Default Noise when heater on
I notice when I put on the heat on I hear a chirping/squeeking noise coming from the engine area, like a belt or something. The funny thing is when I put it on the ECON button the noise stops, when I turn the ECON button off it starts again.
Is this a pulley or compressor issue?, if so how hard is it to replace.
For now I'm running heatr on ECON to avoid the noise, let me know.
Old Feb 20, 2014 | 09:07 AM
mtroxel's Avatar
Same on my 2.8. If the Econ is on but the AC compressor isn't running, I get a noise from the AC clutch area. Turn off the Econ in the winter and its solved. I bought it at 93K miles, I just turned 200K yesterday so it it's like mine, don't worry.
Old Feb 20, 2014 | 09:36 AM
morpheous's Avatar
For now I'm running heat on ECON to avoid the noise, let me know.
Your AC belt is wearing out. Needs to be changed. Its probably dried and cracked, causing that squeak sound.
The reason the sound goes away, when you press ECON, the AC compressor is turned off, so the AC belt isn't being used. Its not normal, it needs to be taken care of, not ignored. It doesn't need to be done, right away or anything but something to keep in mind, say when you're about to get a timing belt done, be sure to replace the AC clutch belt, too.
I never hear any squeaking when i turn on my suppressor by turning the ECON button off.
Old Feb 20, 2014 | 11:14 AM
kozhouse's Avatar
Thanks for the help, another project added to the list once this snow clears out in the northeast. Can't wait for the Spring...
Old Feb 20, 2014 | 11:35 AM
Mad Cow's Avatar
The 2.8 has one accessory belt doesn't it? I'd look into the accessory belt and tensioner, both could squeak when under load.
Old Feb 20, 2014 | 11:39 AM
mtroxel's Avatar
Yea, no AC belt on the 2.8. It's all off the serp belt. Not sure about the OP's problem, but I've had two serp belts in the last 100,000 miles and it did not affect my problem. Mine is all about the AC clutch but doesn't seem to be a real problem.
Old Feb 20, 2014 | 11:54 AM
kozhouse's Avatar
Yeah, I looked last night and I could see a serp belt, so what would i have to change to stop the noise?, just replace pulley or are there other belts behind the serp belt.
I'm confused....
Old Feb 20, 2014 | 11:58 AM
Mad Cow's Avatar
You'd have to find out where the noise is coming from. Spin each pulley until you find the one making noise.
Old Feb 21, 2014 | 03:02 PM
hartsoe1's Avatar
My 1.8 has a chirping/squeaking noise behind the dash that I have determined is the hvac fan. manually change your fan speed on the hvac unit when you hear it just to eliminate that as the potential problem. granted, a belt squeak is much louder than a fan squeak, from outside of the car, anyway. I'm surprised your AC compressor comes on in the winter time even without ECON pressed. the compressor does run with defrost on.
little_town_audi_owner
Jun 27, 2013 10:37 AM
Jackmup
Dec 24, 2012 09:30 AM
Mashina
Mar 10, 2008 09:08 PM
sollyd25
Jan 17, 2008 10:31 AM
kriptonik
Dec 19, 2006 12:46 AM
