not starting
Old Oct 3, 2014 | 03:08 PM
patc's Avatar
Default not starting
Hi all ive got an 2000 a4 2.8 quattro that wont start. turns over ok,, changed fuel pump, got spark, checked relay and fuse,s
Old Oct 15, 2014 | 02:43 PM
patc's Avatar
well im giving up with this car so am breaking it
Old Oct 18, 2014 | 08:45 AM
Mark C's Avatar
Believe it or not, but a bad temperature sensor will make a 2.8L almost impossible to start. They act like a flooded carbureted car because the computer thinks the car is hot when its not. also if you temp and oil lights are flashing when your cranking it, check your crankshaft sensor it may be bad. Can you get any fault codes out of the engine controller?
Old Oct 20, 2014 | 09:21 AM
patc's Avatar
changed both above, god are bits Pricey. still not starting
Old Oct 21, 2014 | 07:13 PM
Mark C's Avatar
Are you getting any codes? Throwing parts at it can be pricey, you have to check codes or you'll end up replacing everything on the car and may never find it.
I got a crankshaft sensor signal low when my crankshaft sensor went bad, insulation was coming off the wire between the back of the engine and the connector on the fire wall.
Old Oct 21, 2014 | 08:11 PM
avtechinbtown's Avatar
Need more info. Did it die while driving? You need 4 things for it to start-compression spark fuel and air. Start there. Then move on to timing etc. Do you have good battery voltage?
Old Oct 22, 2014 | 08:09 AM
patc's Avatar
needs a new engine, no compression in 2 cylinders
makhack
Jun 23, 2011 12:42 PM
Audcura
Mar 9, 2010 11:48 PM
jojoenglish85
Feb 2, 2009 03:30 PM
Honda882000
Dec 27, 2007 10:37 PM
doubleDee
Sep 18, 2007 07:27 AM
