Not your average oil pressure issue
Old Dec 30, 2008 | 09:39 PM
mott6904's Avatar
I think im going to try the kerosene engine flush, pull the oil filter housing and clean it and the add mobile one with a oem filter. If that doesnt work i guess i will buy the .9 bar oil light switch to replace the 1.4bar thats in it right now.
Old Dec 30, 2008 | 11:31 PM
Tweaked's Avatar
Originally Posted by RyanSweeney
Any of you guys ever use K&N oil filters? No one has mentioned them, so I wondered how the ranked. I'm using one now....they're HUGE!
Don't bother. The OEM, Bosch, Mann, and even Wix and Mobil1 replacements are cheap. No manufacturer uses K&N as original equipment. There is a reason for that. Although, I've never been a fan of K&N products...
Old Dec 30, 2008 | 11:40 PM
Tweaked's Avatar
Wait, you're trying to diagnose poor oil pressure and you have incorrect sensors installed?
Old Dec 30, 2008 | 11:46 PM
RyanSweeney's Avatar
Let's talk about this kerosene engine flush. I've heard about it, but I'm scared to death to do it.
What's your procedure for doing this?
Old Dec 30, 2008 | 11:49 PM
I first picked up a Mobil 1 filter, but then I realized that AutoZone was running a special on any 5 quarts of Castrol Syntec and a K&N filter for $26.99....I figured K&N would have at least made a good oil filter.
Old Dec 30, 2008 | 11:50 PM
Tweaked's Avatar
But K&N doesn't make good anything.
Old Dec 31, 2008 | 01:01 AM
mott6904's Avatar
Im still trying to figure out if i have a oil pressure problem or if the incorrect sensor was installed. It never dips below 15 and idle which i thought was fine but the oil light comes on a 25 psi when i start driving. I removed the old switch and replaced with the same part number. Wouldnt you think that 15 psi at idle was sufficent? I thought the spec for oil pressure switch was a little high and then someone mentioned on another forum about a .9 bar switch.
As far as the diesel flush goes it scares the hell out of me also, but a guy i know does it to his 70 something dodge truck and it runs like a top. Im still debating on doing this
nicole12345
Oct 3, 2015 05:51 PM
little_town_audi_owner
Apr 24, 2014 08:05 PM
A44Hersh
Jul 2, 2013 01:09 PM
aeeroN
May 11, 2011 08:33 AM
jhanson25
May 24, 2010 01:50 PM
