obd 2 not connecting
Old Sep 22, 2009 | 12:42 AM
joe99a4's Avatar
Default obd 2 not connecting
My check engine light is on. i tried to get the code with an obd2 scanner but it wasnt able to connect with the car. i have no idea where to go from here. Any help would be appreciated.
Old Sep 22, 2009 | 01:33 AM
Tweaked's Avatar
Is the factory radio installed?
What scanner do you have?
Old Sep 22, 2009 | 04:38 PM
joe99a4's Avatar
its just a basic obd2 code reader. it wont establish a connection with the car.
Old Sep 22, 2009 | 09:23 PM
SVT_BRYAN's Avatar
I've been having the same issue with my car. I have a VAG-COM and cant get into the car.
Old Sep 23, 2009 | 10:07 AM
Tweaked's Avatar
Sounds like a K-line issue. If there's an aftermarket or broken radio in the car, usually you start there.
Check all the fuses. I believe there is a K-line fuse. Then, pull the radio and be sure te connectors are not cut up or corroded. Use some stabilant or contact cleaner on them and plug the radio back in.
Old Sep 23, 2009 | 02:42 PM
ghost6303's Avatar
also is your ABS light on?
Old Sep 23, 2009 | 04:21 PM
joe99a4's Avatar
all my fuses are good. yes i have an after market stereo but all my connections seem good. where can i find that k line fuse??
Old Sep 23, 2009 | 07:10 PM
ghost6303's Avatar
aftermarket stereos can disrupt the OBD port. its probably not a fuse.
Old Sep 23, 2009 | 07:25 PM
joe99a4's Avatar
what do i do to fix it?
Old Sep 23, 2009 | 07:37 PM
Patty J's Avatar
Member
i had this same problem last week....to be honest it was my coil pack but i see that is was broken replaced it and connected no problem afterwards goodluck
