Oil Change FROM HELL !!! Is it totaled??
Old Sep 20, 2010 | 10:27 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Originally Posted by catmandu
There's a **** analogy here, but for the sake of all that is holy, I shall refrain.
*nudge nudge*
Old Sep 20, 2010 | 10:33 PM
Tourbo24's Avatar
lmao i hate to admit it but i did the same thing not too long ago. but everything worked out fine for me.
Old Sep 20, 2010 | 11:03 PM
Chewster's Avatar
Wow after reading all of that NONE of that actaully told me anything!! YA I FUCKED UP!!! I admit that now and I have been working on cars for 15 years I have been second guessning myself for the last month on this one!! and YES that was my post from before I just NOW got the fluid back into the tranny! so IS MY CAR SAVEABLE??? and Tourbo24 did you have any Check Engine Lights afterwards?? Is my torque Converter toast or is it still low on fluid??? PLEASE I KNOW I AM AN IDIOT I JUST NEED ANSWERS NOT CRITISIM!!
Old Sep 20, 2010 | 11:38 PM
ImTheDevil's Avatar
The only thing about the way you went about fixing this that left me apprehensive was your statement of simply refilling the transmission. Everybody steps on their dick with cars on occasion - god knows I've done some dumb **** and the rest of the guys probably have too. The biggest thing on your side is that it sounds like you drove a very short distance before pulling over and going back and my views below are based on that assumption. Here goes my view on it:
too much oil - you drained it and refilled it properly. Fine. The considerable increase in oil pressure very likely forced oil past a number of seals, but once the pressure was correct after your drain and refill, that's likely taken care of. There's a good chance that your cat is going to be ok.
Cam circuit fault - not sure honestly, but clear the code and see if it comes back. It may or may not. If it does, deal with it then.
Trans fluid - a tip tranny can't just be refilled. It needs to be done with the car perfectly level and at a certain temperature while being monitored with vagcom. It's very likely that your refill is not correct and needs to be redone. There is a DIY out there you can use. If it's not feasible to DIY it, trailer the car to a shop that can. Do not drive it there. You may not have ruined it but continued driving may kill it.
Honestly, again going on the implication that you drove very little with the car in this condition, chances are you aren't gonna lose the car or your *** in trying to fix it.
Old Sep 20, 2010 | 11:45 PM
sa9023's Avatar
Don't feel bad, we all make mistakes. Plus a guy I know took his 99 1.8T to Jiffy Lube and the same thing happened. Of course they denied it. But he got it refilled and the car is fine now
Old Sep 21, 2010 | 12:14 AM
Tourbo24's Avatar
ya i had a check engine light on and the car was shifting weird, but then i decided not to drive it and had it towed to my mechanic who drained the rest of the oil and refiled it with new synthetic tranny oil. after that the check engine light turned off.
edit: ohh and if your light is still on you might be low on fluid.. btw how did you fill it cuz you need a special tool that pumps the oil in the same way it came out.
Old Sep 21, 2010 | 01:02 AM
joenelson7687's Avatar
LOL this is the wrong forum to post an epic fail and not expect to be messed with just a little...
Old Sep 21, 2010 | 07:16 AM
  #18
CCA4's Avatar
Is this the second time you've done this.....?
I feel like this is turning into the new "50lb-bag-of-sand-in-the-intake" thread lol
Old Sep 21, 2010 | 09:10 AM
  #19
Chewster's Avatar
LOL no I have only done this once (the older post was from me but I just NOW got it refilled) and I went on here and Used the DIY info about refillin the tranny I did not have a Vag Com though, I just kept pumping fluid in cyclying the gears pumped more in let it sit warm it up and repeat until i got 6 lieters back in I still have a qt of a lieter left and i prob need to do it again just to make sure, I will try this and clear the codes and see what happens...
Old Sep 21, 2010 | 10:07 AM
  #20
CCA4's Avatar
For the benefit of anyone who might find this thread using the search function (if such a person even exists), I'm going to post these two pictures:
Carry on.
