oil leak
Old Oct 20, 2009 | 05:50 AM
cwedholm1's Avatar
Default oil leak
I have a 2001 a4 2.8 quattro with a oil leak,I haven't crawled under the car yet but, I was wondering if there is common areas that these leak oil? Thanks
Old Oct 20, 2009 | 06:41 AM
Veegard's Avatar
Old Oct 20, 2009 | 11:27 PM
A4 2000's Avatar
I have a 1.8, but I'd suggest taking off the belly pan for a little while. Clean up the whole engine bay and take a look at it everyday with a flashlight. I found a couple myself. First, I found a leak from where the oil drains because the previous owner put the wrong drain plug in and it didn't even have a washer. After that stopped leaking, I found another spot where there's a leak coming from the front of where the oil pan connects. That one's a really slow leak at least.
Old Oct 21, 2009 | 08:09 AM
9a49's Avatar
valve covers.....
Old Oct 25, 2009 | 04:22 PM
cwedholm1's Avatar
Default oil leak
I crawled under the car today and removed the plastic covers on the engine and the oil is definently coming from the valve covers. It doesn't look like a bad job to do but, would appreciate any insight. 2001 2.8 Thanks
Old Oct 25, 2009 | 04:31 PM
dragonrage's Avatar
Valve cover gaskets are straightforward.
Old Oct 25, 2009 | 10:20 PM
ImTheDevil's Avatar
Straightforward and covered in tremendous detail often on here . You'll find everything you could want to know about it with ease.
Old Oct 26, 2009 | 10:01 PM
Interceptor's Avatar
X10...I noticed a small spot on the ground about the size of a fifty cent piece. Gasket is leaking but I'm having issues with the pcv hoses gumming up and I'm leaning towards the suction pump.
Old Oct 27, 2009 | 04:38 PM
dragonrage's Avatar
Yes, definitely check that out. Look into a catch can for the oil. There's also a revised suction pump which might help some (but don't expect miracles) for like $20ish. A clogged suction pump/PCV setup can blow other oil seals.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
