Ok, only 8 codes left to figure out! Give me some help
Old Nov 16, 2009 | 11:49 PM
99A6Q's Avatar
Default Ok, only 8 codes left to figure out! Give me some help
Ok, here is the story.....
A laddar fell off a constuction truck and i couldnt avoid it and drove right over it ripping the catalytic convertors off and messing up the exhaust since my car is lowered. Exhaust was dangling at the scene of the accident so the o2 sensors had to be clipped for the exhaust to come off so the car could move. Long story short.....insurance totaled the car and I bought it back cause there was nothing wrong with it. I put new exhaust on it.
Now I have 8 codes. 4 are for o2 sensors even though all 4 of them were replaced with new ones.
The other 4:
P1435
P1421
P1425
P1472
All of them are short to grounds. Does anyone have a wiring diagram for this car? They are starting to drive me crazy. I assume it has something to do with the o2 sensor harnesses since that is what was damaged to begin with but I fixed that and i have checked back over it several times to make sure.
The car is a 98 A4 2.8, 5 speed.
If anyone has any ideas let me know......
Old Nov 17, 2009 | 12:00 AM
ghost6303's Avatar
P1435 Secondary Air Injection Pump Relay Circuit Short To Ground
P1421 Secondary Air Injection Valve Circuit Short To Ground
P1425 Tank Ventilation Valve Short To Ground
P1472 EVAP Control System LDP Circuit Short To Ground
http://www.obd-codes.com/trouble_codes/volkswagen/
the stickies are your friend. you should have read them before your first post. the 'modification & maintenance' sticky has just about all the diagrams you need in the very first link in it.
those codes are all related to the evap system, not to the O2 sensors, though i couldnt tell you specifically because you failed to give us those codes. clear them all and see which come back. none of the listed codes are especially dangerous to anything, they are for emissions only.
Old Nov 17, 2009 | 12:04 AM
auditech79's Avatar
Not to mention i think he has a 4.2L A6, not a B5 A4.
Old Nov 17, 2009 | 12:20 AM
Midniteoyl's Avatar
Quit looking at the O2 harness and look around the underside some more.. there is a harness with chewed up wires in it. Cant tell you where its at though..
Old Nov 17, 2009 | 08:30 AM
99A6Q's Avatar
Yeah, this is for my A4, not my old A6, I sold that car.
Yeah i figured that a harness is chewed up somewhere but I cant find it. I guess I will get under it again and see if I can find a spot on the wiring diagram that would cause all of these codes to come on.
Old Nov 17, 2009 | 12:12 PM
Midniteoyl's Avatar
.. Was only trying to break the appearent 'fixation' we all seem to get when searching for problems.. "I cant find it and looked 30 times! But it must be this... just has to be"
Old Nov 17, 2009 | 06:57 PM
auditech79's Avatar
A common place for wiring harness problems is under the front bulkhead, the bottom of the bulkhead is sharp and tends to wear through the protective wiring covering.
tties4me
Jul 3, 2014 08:12 PM
adam73647
Jan 2, 2014 09:54 AM
frankiej
Oct 24, 2013 05:13 PM
allroadftw
Jun 14, 2012 12:48 AM
moosefist
Dec 1, 2009 11:53 PM
