One question!
Old Oct 6, 2008 | 03:59 PM
Isramirez21's Avatar
Unhappy Car won't start! Check engine light! (P1340 code)Help plz
canceled
Old Oct 6, 2008 | 05:41 PM
Tweaked's Avatar
Codes, please!
Old Oct 6, 2008 | 06:02 PM
ok they just scanned it.
these are the codes:
P1340 definition ckp/cmp sensor signals out of sequence
explanation
timing belt jumped
probable causes
1-Failed cmp or ckp sensor
2-Poor electrical connection
P1392 definition Cmp sensor bank 2 open circuit/short to positive
explanation
open or short circuit codition
probable cause
1- Failed CMP sensor
^^OK they gave me two codes ^^^
thanks
Old Oct 7, 2008 | 12:16 AM
Tweaked's Avatar
And you didn't bend any valves? You got lucky! Change the belt, tensioners, and water pump while your at it.
Old Oct 7, 2008 | 02:32 PM
I just have to replace the camshaft sensor, for now I just cleaned it using electronic cleaner. Now the check engine light is gone and the car start and runs normal.:-) Im not sure, probably is permanent and I have to change the sensor eventually.
Thanks for the help buddy
Old Oct 7, 2008 | 05:07 PM
Tweaked's Avatar
Wait so, the belt jumped or it was just a bad sensor...?
Old Oct 7, 2008 | 06:09 PM
It's just a bad sensor I guess. (the camshaft sensor)
After I cleaned the connector the car starts and runs normal. I haven't changed the sensor yet since the cleaning did the trick.
I only cleaned one camshaft connector, I know there are two, but I couldn't find the other one on the passager's side. Do you know where it could be?
Old Oct 8, 2008 | 12:07 AM
RABBITRACR's Avatar
the passenger side one is on the front of the head behind the timming belt covers. take the plactic cover off the p/s valve cover look straight down where the black metal cover for the timming belt bolts to the head facing twards the power steering pump and you will see the plug.
Old Oct 8, 2008 | 09:31 AM
I'll try to find it today.:-)
Thank you
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
