One question!
ok they just scanned it.
these are the codes:
P1340 definition ckp/cmp sensor signals out of sequence
explanation
timing belt jumped
probable causes
1-Failed cmp or ckp sensor
2-Poor electrical connection
P1392 definition Cmp sensor bank 2 open circuit/short to positive
explanation
open or short circuit codition
probable cause
1- Failed CMP sensor
^^OK they gave me two codes ^^^
thanks
explanation
timing belt jumped
probable causes
explanation
probable cause
thanks
Thanks for the help buddy
I just have to replace the camshaft sensor, for now I just cleaned it using electronic cleaner. Now the check engine light is gone and the car start and runs normal.:-) Im not sure, probably is permanent and I have to change the sensor eventually.
It's just a bad sensor I guess. (the camshaft sensor)
After I cleaned the connector the car starts and runs normal. I haven't changed the sensor yet since the cleaning did the trick.
I only cleaned one camshaft connector, I know there are two, but I couldn't find the other one on the passager's side. Do you know where it could be?
the passenger side one is on the front of the head behind the timming belt covers. take the plactic cover off the p/s valve cover look straight down where the black metal cover for the timming belt bolts to the head facing twards the power steering pump and you will see the plug.
Thank you
akitamike
Jun 9, 2008 11:05 AM
SouthernAudi
Oct 14, 2007 06:47 PM
