Overheating issues. Please Help!!!
Old Mar 9, 2012 | 08:02 AM
rekabj1108's Avatar
Exclamation Overheating issues. Please Help!!!
Ok, I'll start from the beginning. I replaced my water pump a year ago. Then just before winter (this past October) I replaced the thermostat due to no heat. Car wasnt getting up to temp. When I replaced it the car did have heat but would start to overheat after driving about 15 miles. The heat starts to go away as the car starts to overheat. Then climbs fast. I do have a couple coolant leaks. One at the coolant resevoir and at the oil cooler. I dont have any oil in my coolant. Could the bad resevoir cause overheating due to lack of pressure in the coolant system? Also my lower radiator hose never gets hot. So this leads me to believe the system doesnt have enough pressure... Please, any advice is appreciated. THANK YOU!!!
Old Mar 9, 2012 | 08:18 AM
M5S5's Avatar
Tech Certified
Fix the coolant leaks , fill & bleed cooling system then see what happens.
Old Mar 9, 2012 | 08:06 PM
ou2mame's Avatar
yeah you can't bleed the system if there's leaks, and if there's air its not going to flow correctly. when i did my thermostat a few months ago i started it to make sure everything was on tight and the car got up to 235f, and then i bled it and it came back down to 198 or so.
Old Mar 9, 2012 | 08:16 PM
ImTheDevil's Avatar
Sounds like air in the system for sure. Air bubbles will get stuck behind the thermostat and trap it, keeping it from opening. That's why your lower hose isn't warm. Run it until it starts overheating (3/4 of the way up the gauge), then shut it down. Let it cool a bit and then carefully pop the cap to purge pressure (this is "burping" the system). Top off the reservoir and repeat. That should help get the air out and let the system work as designed.
jessb6a4
Mar 13, 2014 08:03 PM
BreezeThe TT
Sep 1, 2013 07:59 PM
catburner909
Sep 21, 2012 02:10 AM
fireman9585
Aug 7, 2011 03:13 PM
kaabee
Jul 12, 2009 04:29 PM
