P1517 Main relay problem
Old Oct 1, 2015 | 03:33 PM
Tony Xayyaraj's Avatar
Default audi a4
i have a problem with a 2004 audi a4. i have a p1602 code. i have been doing some research and i read somthing about finding the fuse 30. does anyone know where fuse 30 is located at on a 2004 audi a4?
Old Oct 1, 2015 | 03:49 PM
where is the fuse 30 located in the 2004 audi a4. i have the same problem. it started yesterday. i just replaced the turbo and the engine. i was in the ecu and was wiggling around the 373 fuse and it turned on. now it just makes a loud click when i turn the car on. can you help me please?
Old Oct 7, 2015 | 02:55 PM
jacquesdub1981's Avatar
Mine was located under the hood. Remove the heed cowl(piece of plastic over the battery) and look near the fire wall drivers side. There should be a black box with two bolts holding the lid on. Remove the lid and there is the ECU and relay. Hope this helps.
Old Aug 5, 2016 | 11:14 AM
runcatrun7@hotmail.com's Avatar
Hey i got the same code p1517 plus also throttle body under voltage or sometimes says throttle body fails tonadjust or something like that. I had change the throttle body but i still need to get the relay #30. Car still nonturning on. Need some help. Engine atw 1.8 2000
Old May 7, 2020 | 09:30 PM
t1bud42's Avatar
Originally Posted by jacquesdub1981
I know this thread is very old and you have more than likely solved your problem, But for the sake of helping someone else here is my experience with this code. My 2000 A4 1.8 would die randomly going down the hwy then not start back up for several minutes. Disconnecting the battery seemed to help but only for a short time. I racked my brain thinking what it could be. I went from fuel pump to camshaft sensor. In the end I located the ECU relay. It`s in the ECU box, labeled 30. An obvious spot but there isn't a relay list in any book I have come across. Once the relay was out I took it apart and found that the braided copper wire was touching one of the poles. I simply pushed it up so it was free then put it back in the car. Not a single problem or a P1517 code since. They are very cheap ($13 at most places) so it`s a good idea to get a spare. When ordering it give the 9 digit number on the side of the relay housing. I am new to the Audi world and this site has helped me a great deal. I hope this helps anyone in the future.
I don’t have any relays in my ecu box and can’t find the relay 30 for the life of me..
Crookedtoad
Feb 19, 2015 04:43 PM
Gary-a392
Dec 13, 2014 02:09 PM
Mtsjf42
Oct 14, 2013 07:23 PM
msotiroglou
Jul 1, 2010 02:53 PM
groundstarr
Apr 17, 2009 07:57 PM
