P1559 Idle Speed Control, throttle position. Adaptation Malfunction
Old 01-22-2010, 07:36 PM
xsive41's Avatar
Default P1559 Idle Speed Control, throttle position. Adaptation Malfunction
got this code along with a couple of others, one was the 1st o2 sensor and the other the coolant temp sensor... i replaced both the sensors and that cleared the respective codes
i cleaned the TB and TBS and replaced then took it to the shop around the corner who has been nice enough to help with these problems (thanks chucks imports) he hooked it up to his scanner but was unable to reprogram the TBS for some reason or clear the code
i also read online that disconnecting the battery and turning the car to on but not start would reprogram as well... tried this nothing happened
while was trying to tackle these problems, new development the CEL will flash from time to time while driving mainly when shifting from 1st to 2nd
any help would be greatly appreciated
corupt
08-12-2019 03:44 PM
bluetang77
02-20-2018 10:13 AM
carlv
05-08-2009 03:39 AM
exodi
09-29-2006 09:11 AM
stevem8
05-25-2006 09:15 PM
Quick Reply: P1559 Idle Speed Control, throttle position. Adaptation Malfunction
