Parking Brake Question
Old May 29, 2010 | 10:14 PM
jterranova0's Avatar
Question Parking Brake Question
I'm having an issue removing the parking brake cable from the bracket on the caliper. Is there some trick to getting the cable out or should it be as easy as sliding it out?
Its the rear passenger side, quattro.
Old May 29, 2010 | 10:18 PM
bradtyler02's Avatar
A little trick I used was to compress it (by hand, or pull up the e-brake) then use a zip tie to hold the bracket in place. Release tension off the cable, and work it out. It's still a little tricky, but it worked for me.
Old May 29, 2010 | 10:23 PM
chocalotstarfish's Avatar
Super Moderator
My cable was broke so couldnt do that. C-clamp is what I used.
Old May 30, 2010 | 09:30 AM
Polisan's Avatar
mine was seized so i used a hammer then pulled the spring off
Old Jun 1, 2010 | 01:06 AM
Thanks everybody. All done. I ended up just doing all 4 calipers, rotors, pads and did the wheel bearings while I was at it. Drives like brand new ^^
Old Jun 1, 2010 | 02:50 AM
Glad to hear it all worked out. Damn I can't wait to get some wrench time in! I got an inch that needs to be scratched! (Or is it a scratch that needs to be itched?)
Rickardc
Aug 17, 2014 10:29 PM
Nevalite
Oct 24, 2010 05:49 PM
sacramentoquattro
B7 Models
18
Jan 14, 2009 11:00 PM
jakej
Nov 12, 2008 08:55 PM
Audiva
Jun 11, 2007 08:33 PM
