Parking Brake Question
I'm having an issue removing the parking brake cable from the bracket on the caliper. Is there some trick to getting the cable out or should it be as easy as sliding it out?
Its the rear passenger side, quattro.
A little trick I used was to compress it (by hand, or pull up the e-brake) then use a zip tie to hold the bracket in place. Release tension off the cable, and work it out. It's still a little tricky, but it worked for me.
My cable was broke so couldnt do that. C-clamp is what I used.
