PLEASE HELP WITH CV BOOT!!! URGENT!!!
Old Apr 18, 2008 | 10:02 PM
j_ripper19's Avatar
Default PLEASE HELP WITH CV BOOT!!! URGENT!!!
Hello and thanks in advance for reading this,
I was replacing the CV boot in the right side. Everything was going fine, removed the lower control arms and stuck the new boot. I hammered the cv joint back in the axle and it seemed fine, but when putting everything back together the length of the axle+joint seemed smaller than it should and then there wasn't enough length to reach the hub. I've done a few cv boots and this never happened to me. Is it possible that I hammered the joint too much and put it too much inside??!!? Please help as I don't know what to do.
Any help is more than appreciated!
Old Apr 18, 2008 | 10:43 PM
hiwords's Avatar
Default RE: PLEASE HELP WITH CV BOOT!!! URGENT!!!
check to see if the other side of the axle that is hooked up to the center diff is messed up
Old Apr 19, 2008 | 09:31 AM
heloman28's Avatar
You would've known if you went past the notch. Did you take the axle off the car completely?
super_sweenqey
Jul 2, 2012 04:53 PM
chickeneater
Dec 7, 2010 12:41 AM
07titanium
B7 Models
Nov 22, 2009 07:31 PM
gedas429
Aug 28, 2009 03:19 PM
