pleasse help!
Old Feb 16, 2008 | 08:27 PM
alwaysaudi's Avatar
Default pleasse help!
Hello, i am new to the site but i have a problem in need of fixing. last night i went to start my car and when i did i had no headlights. i thought it was a fuse, but when i switched them, nothing happened. Also the turn signals and the windsheild wipers dont work either. can anyone please give me some info on what might have caused this!!!!
Thanks
Old Feb 16, 2008 | 08:54 PM
hiwords's Avatar
Default RE: pleasse help!
probably a bad connection or a short. start looking around the steering column area.
Old Feb 16, 2008 | 08:57 PM
alwaysaudi's Avatar
What do you mean by start looking around the steering column? what am i looking for?
Old Feb 17, 2008 | 12:27 AM
turbo kraut's Avatar
Tech Guru
loose or frayed wires....... if you have a tester(ohms meter, i think)...... test the wires around the switch for volts
Old Feb 17, 2008 | 12:39 PM
alwaysaudi's Avatar
bump. sorry i dont know much about cars. i have no idea what im looking for? is there any chace it is a relay or something? Could only a short cause these 3 things to fail at the same time?
Old Feb 17, 2008 | 01:40 PM
ImTheDevil's Avatar
In order to access the wiring for the switch, you will have to remove the steering wheel. Go to www.audiworld.com and check their tech section for the article on replacing the combination switch (that's the switch in question here). It will walk you through the removal, which is easy, and will allow you to check the wiring at the switch harness to see whether it's shorted or any wires are broken. Make sure your fuses are all OK too (use a multimeter to make sure they're good - a blown fuse can sometimes not appear to be blown). You may have something as simple as that.
Old Feb 17, 2008 | 09:08 PM
alwaysaudi's Avatar
Thanks. Guess i need to order the combo piece. What about the turnsignals not working? same peice? or do i need to get a turnsignal switch also?
Old Feb 17, 2008 | 10:22 PM
ImTheDevil's Avatar
The combination switch incorporates all of it.
Old Feb 17, 2008 | 11:18 PM
david9999's Avatar
I'm assuming that your car is running OK?
It sounds more to me like an ignition switch problem.
The multifunction switch shouldn't affect the wipers.
Old Feb 18, 2008 | 01:02 AM
alwaysaudi's Avatar
also does anyoe kow the specifics about what size the tools i need are? Thanks
