pleasse help!
Old Feb 18, 2008 | 01:05 AM
alwaysaudi's Avatar
Default RE: pleasse help!
ORIGINAL: david9999
I'm assuming that your car is running OK?
It sounds more to me like an ignition switch problem.
The multifunction switch shouldn't affect the wipers.
Car is Running GREAT. only problems are no turn signals,(hazards work) no Wipers or wiper fluid spray, and no headlights. high beams are fine when held back but not when pressed and locked foward. really starting to think its teh headlight switch but i dont know what to do about the wipers.
Old Feb 18, 2008 | 01:17 AM
Babz's Avatar
Its most probably a ignition switch problem. search your year and car model + recall on google and something will pop up.
Old Feb 18, 2008 | 09:58 PM
alwaysaudi's Avatar
i changed the ignition switch and everything works but i messed up the placement of the actual ignition you put the key into.
Does anyone know how to adjust it? i think its stuck so taht it starts on accessory. now my car wont start but i do have all of my pwer back. lights wipers and horn etc.
Thanks
Old Feb 18, 2008 | 10:54 PM
alwaysaudi's Avatar
HA we ll i fixed everythig BUT the car wont stay on. it wants to start and i can pump the gas and keep it going but it wnats to die and then does. have i misaligned something? PLEASE HELP
Old Feb 19, 2008 | 12:30 AM
alwaysaudi's Avatar
bump please help
Old Feb 19, 2008 | 01:37 AM
alwaysaudi's Avatar
so yea now the car wont start but trys. everything else works fine. did i mess something up installing the new ignition switch?
Old Feb 19, 2008 | 12:17 PM
alwaysaudi's Avatar
HEEEEEEEEEEEEEEEEELP!!!!!!!!!!!!!! car wont stay on!!
Old Feb 19, 2008 | 03:18 PM
  #18
TommyGunns's Avatar
Before the car dies, does is say something in the center display about security mode? The extra key the dealership gave us for the Passat would start the car for a few seconds, and then stop. But the radio etc worked. They had to reprogram the key for the car.
Old Feb 19, 2008 | 03:34 PM
  #19
CRAZYHAWK's Avatar
Try a throttle body alignment.
Wicked V6
Jun 29, 2010 12:41 PM
