Pro Diag :(
Well, I really screwed up this time. I bought a palm iiic with pro diag (vag com for palm pilots), now called vad mobile, from a guy on here called remembertofocus. Its worked great for years, and I had a backup of the palm so if the battery went dead I could restore it. Well two years later, and two computer reformats later, the damn battery died on my palm, and I dont have any activation keys or the backup... I tried to send an email to vad mobile and I got an undeliverable message back (ill try calling them tomorrow), I sent remembertofocus an email on AIM, he told me he could restore it if the battery ever died, hopefully he will follow through, somehow Im thinking I wont be so lucky.
Did some messing around with my cable connected to my laptop. Ive tried various versions of vagcom in windows 7 and windows xp and all I can connect to is engine, radio and HVAC. The two modules I need to connect to wont connect. When i try to connect to ABS, the abs light will come on, it does its three beeps, then shuts off, vag com retries a bunch of times and the abs light keeps coming on then shutting off, and it finally gives up. When I try to connect to the airbags, it says it failed and I need to turn the car off, and keeps repeating that every time I retry...
I cant do a full scan at once, its unregistered. The error I get is cant synch baud rate, so I cant even get to the codes.. Im using a serial cable with a usb to serial converter if that makes any difference, the engine codes work just fine, but thats about it. I tried playing with the settings but still cant get it to work.
