Problems in the Cold (Please Help)
Old Feb 28, 2008 | 11:31 AM
TJP13088's Avatar
Default Problems in the Cold (Please Help)
I recently had my throttle body replaced and since then, my car has been squeaking quite a bit following start up. The noise seems to be coming from the front of the engine (timing belt perhaps) and only occurs when the engine temperature is cold. Once the temperature gague begins to rise, the noise stops. I would be surprised if the timing belt needed replacement as I had it done about 10,000 miles ago; maybe its a roller or something. Any ideas would be great. Thanks guys.
Update: after letting the car heat up, I felt the exhaust and noticed that there was a bit of water in it. I checked the oil and noticed a white or off white colored grease or gelatinous substance mixed with the oil. What is Going on?
Old Feb 28, 2008 | 02:38 PM
TJP13088's Avatar
Default RE: Squeaking When Cold
bump
Old Feb 28, 2008 | 02:45 PM
SAudi's Avatar
sounds like a loose serpintine belt, open her up and see if you have a loose belt somewhere
Old Feb 29, 2008 | 02:33 PM
TJP13088's Avatar
bump
Old Feb 29, 2008 | 02:38 PM
techbod's Avatar
timing belt? I doubt it that would be obvious, could be the serpentine belt slipping or wasted tensioner
george1546
Apr 13, 2015 11:40 AM
Fifi
Jan 24, 2015 05:16 PM
MULEPERFORMANCE
Jul 23, 2010 01:12 AM
motojoeis01
Dec 20, 2009 11:22 AM
connman
B7 Models
Feb 20, 2008 11:35 AM
