Projector headlight question
Old Dec 24, 2008 | 09:33 AM
mrbloink's Avatar
Default Projector headlight question
Hey there. I am looking to install some projector headlights into my 98 1.8t. My questions are, will they simply install straight into the old spot, or will I have to do any trimming to fit them in there? And, Will i need to use hid's with them, or just the stock bulbs?
Old Dec 24, 2008 | 11:10 AM
jskinny's Avatar
if you get one-piece you'll have to trim, 2 piece you shouldnt have to.
you can use either bulbs but some projectors are made out of plastic that will melt with hid's.
I just posted some pics of one pieces i got
https://www.audiforums.com/forum/sho...d.php?t=121414
also, if you search "for headlights" there are a million different threads about what you have to do and how to do it
Old Dec 24, 2008 | 11:33 AM
Trey25's Avatar
You don't have to get HID bulbs but they are much better than stock.
http://www.audiworld.com/tech/ext17.shtml
http://www.audiworld.com/tech/ext52.shtml
Old Dec 24, 2008 | 07:43 PM
mrbloink's Avatar
i wasn't sure wether or not to get an hid conversion kit since the hid's take time to charge . what are the benefits to hid's over stock besides brightness?
Old Dec 24, 2008 | 08:29 PM
jskinny's Avatar
I'm not really sure what you mean by time to charge but if you mean the time from when you turn on the light to when they are giving their full output, mine only take like 5 seconds. there is no real disadvantage that i have encountered from having hids other than blinding people when i had them in stock housings (and now also with the projectors since i am having trouble adjusting my new headlights)
I got fairly cheap hids on ebay and have had them for a year+ and they are much brighter than stock which in my opinion is reason enough to get them especially with projectors. i figure the brightness helps them look better as well, with mine I see the sharp cutoff line that probably wouldnt be as obvious with stock lights.
heres some stuff to the benefits of hids, there are a bunch of sites about them
http://www.asiannet.com/tradelead_vi...71698&bos=Sell
Old Dec 24, 2008 | 09:24 PM
airguard350's Avatar
Tech Guru
All I know is that I HATE HIDs on the backroads. I never use my high beams anyways and to me low beam HIDS are as bright if not brighter than halogen high beams.
Old Dec 25, 2008 | 10:26 AM
Siena's Avatar
HID's will not melt OEM ecodes.
Old Dec 25, 2008 | 10:38 AM
mrbloink's Avatar
im just worried about if i ever need to flash my beams in order to warn someone. my fathers car has them and i do like them, just wondering what you guys thought. there isnt anything i can screw up badly if i trim is there?
Thanks for all of your help
Old Dec 25, 2008 | 12:21 PM
Siena's Avatar
No issues with the trimming, you just need to make sure you treat and paint the exposed metal.
Flash warning? You don't flash with your dipped beams, do you?
Old Dec 25, 2008 | 12:33 PM
Dallas09's Avatar
If you flash with your high beams, the lows stay on so theres no issue (same if you just leave the high beams on).. If you flash with the low beams thats OK too since after they are running there is no startup time for them, its instant. Even when they are cold they take very little time to warm up you barley notice it, takes like 5 seconds max and there is still light being put out.
They are brighter for the driver, but I still find them easier on the eyes as an oncoming cars AS LONG AS THEY ARE AIMED right.
