quick Question about a mod..
Old Oct 21, 2010 | 10:10 AM
numlock4045's Avatar
Default quick Question about a mod..
i was searching threw the FAQ.. and seen this https://www.audiforums.com/forum/computer-fuel-systems-27/cheap-power-diode-mbc-boost-gauge-install-63234/ the diode for the map sensor.. will that work on my A4? its a 2000.5 1.8t Q M.
Old Oct 21, 2010 | 12:46 PM
CCA4's Avatar
For shizzle. The diode will work as long as you've got a MAP sensor and a drive-by-wire setup.
Old Oct 21, 2010 | 03:04 PM
ImTheDevil's Avatar
And it's really wise to set up an mbc to keep boost in check so you don't overboost and either go into limp or break something.
Old Oct 21, 2010 | 03:07 PM
CCA4's Avatar
An excellent point. I believe that's mentioned in the DIY that Cincy wrote up, but its pretty important.
Old Oct 21, 2010 | 05:40 PM
getinlost's Avatar
So an older DBW car is SOL?
Old Oct 21, 2010 | 06:21 PM
CCA4's Avatar
Well the diode gets spliced into the MAP sensor wiring, so if you don't have a MAP sensor then yes, you're SOL
Old Oct 21, 2010 | 07:01 PM
joenelson7687's Avatar
Just make sure its a 4.3v1w diode, the 4.7 will still throw you into limp.
jmcdowel
B7 Models
Jan 6, 2014 05:48 PM
grimace132
Nov 21, 2012 08:10 PM
DustanS
Jun 10, 2011 10:45 PM
khj677turbo
Dec 23, 2007 06:00 PM
ThePapaCMan
Apr 11, 2007 02:26 AM
