Radio removal key problem
Old Mar 24, 2008 | 11:11 PM
bigdyll's Avatar
Member
Default Radio removal key problem
Okay, I just got my radio removal key today to do a check up on my headunit. It worked like a charm, slide it in, locked, and pull the unit out. BUT! When I tried to install the HU back, the radio key just won't come out.. is there a specific tab or thing you need to do to release the radio key? Thanks for the info in advance!
PS. it's the Concert I headunit.
Old Mar 25, 2008 | 12:01 AM
vgo's Avatar
vgo
Default RE: Radio removal key problem
im planning in removing mine soon as well. i didnt know i had to use the radio key when putting it back in...i wont be buying me a key, just going to fabricate me one with a sheet of metal i get from work. why not try removing it again, and putting it back without the key...
Old Mar 25, 2008 | 06:00 AM
bigdyll's Avatar
Member
Actually I could NOT get the key out of the radio once I pull the HU out of the slot. The key's basically stuck there on the radio as of now and won't lock the HU in the slot (I can slide it in and out, with the key stuck on it). I don't think you "need" a key to put the radio back in, but I am certainly sure that you "need" a key to unlock and pull out the HU.
Old Mar 25, 2008 | 10:25 AM
TommyGunns's Avatar
Try pushing in on the tab on the back side of the face, along the side of the HU. I just took mine out a few weeks ago to install an MP3 adapter. I had to push the tab while pulling on the key. You might have to wiggle it alittle while pulling it out.
Old Mar 25, 2008 | 11:11 AM
MrFlippant's Avatar
Take the keys out before you put the radio back in. With the radio out, you should be able to reach the tabs that the keys catch on, just release them gently with a small screwdriver or your fingernail or something.
Old Mar 25, 2008 | 09:42 PM
TommyGunns's Avatar
Oh come out, no one is gonna make a joke about that? I'm disapointed!
scskim
Nov 12, 2008 09:04 PM
R3N3G4D3
Aug 15, 2008 01:18 AM
rob67
Jul 10, 2008 04:48 PM
vtchaz
Mar 22, 2006 02:58 PM
hypnotiks
Apr 13, 2005 12:55 PM
