Rear brakes question
Old Jul 2, 2008 | 08:07 PM
domperrion's Avatar
Member
Default Rear brakes question
i Have a 2.8Q and am needing to replace the rear brake pads and i am wondering which kind to buy. buck up and buy a nice set or the cheap ones? suggestions please...
Old Jul 2, 2008 | 08:11 PM
ImTheDevil's Avatar
Default RE: Rear brakes question
Unless it's a track car, buy middle of the road pads. It makes the most sense - the rear brakes only do a small amount of the braking anyhow (maybe 30%), so you don't need high-performance pads. At the same time, it would go against everything I stand for to tell you to buy the cheapo stuff. Ergo, middle of the road is probably fine. If you're going to spend some money on brakes, it's better spent up front since that's where the majority of the braking work is done.
Old Jul 2, 2008 | 09:50 PM
lawnferie's Avatar
i have PBR ceramics all around the car... good stuff!
where i got 'em: www.sasponline.com
good luck
Old Jul 3, 2008 | 12:37 AM
domperrion's Avatar
Member
ok well i live in wisconsin so should i go ceramic or semi-metallic. or just the difference...
Old Jul 3, 2008 | 12:40 AM
hiwords's Avatar
semi is good enough, ceramic will harder and will chew up your rotors faster but has less dust. you hardly use the rears anyways so that's why semi is good enough
Old Jul 3, 2008 | 03:47 PM
lawnferie's Avatar
^^^ +1 for rears, semi is good enough
daze614
May 3, 2014 05:14 PM
NoviceAudiOwnerMarc
Nov 8, 2013 09:08 AM
jackson101
Mar 2, 2013 03:23 PM
DjDiddles
Dec 27, 2007 04:55 PM
Belligerenceā„¢
Nov 22, 2007 01:19 PM
