Rebuilding 1.8T
Old Aug 12, 2012 | 09:41 PM
cstone94's Avatar
Default Rebuilding 1.8T
I'm currently rebuilding my 1.8T, I have new main cap and connecting rod bearings, rings, and gaskets. I've looked everywhere for main cap bearing clearence's when plastigaging. I installed one and it was in between .001 and the next size up, is that good? I torque'd it to 43 ft/lb's and did an extra 90 degree turn, and then reinstalled with assembly lube on the inside of the bearings. This is correct, right?
Old Aug 12, 2012 | 10:05 PM
ImTheDevil's Avatar
Talk to FASTER or redline380 - either can answer that for you easily.
Old Aug 13, 2012 | 08:48 AM
CCA4's Avatar
Bentley calls for clearance between .01mm and .05mm, wear limit is .12mm.
Roughly .00039", .0019", and .0047", respectively.
Last edited by CCA4; Aug 13, 2012 at 11:58 AM. Reason: I accidentally all the maths.
Old Aug 13, 2012 | 10:40 AM
MetalMan's Avatar
Originally Posted by CCA4
Bentley calls for clearance between .01 and .05, wear limit is .12
Do you mean .001, .005, and .012 respectively? .12 is a pretty big gap LOL
Old Aug 13, 2012 | 11:51 AM
CCA4's Avatar
GOOO yes lol. Sorry!! Shouldn't be posting about things this precise before I have coffee. The Bentley specs were in mm, not thousandths. :shifty:
Will correct the original post. Sorry guys!
Old Aug 13, 2012 | 12:56 PM
cstone94's Avatar
Are the thrust washers installed with the 3rd main cap, or do you set them in place with the crank?
Old Aug 13, 2012 | 03:32 PM
cstone94's Avatar
Can anyone tell me if this is oriented right? Is this for the distributor? This is right next to the 4th cylinder in the corner.
Old Aug 13, 2012 | 04:29 PM
CCA4's Avatar
You don't have a distributor, that's the intermediate shaft that drives the oil pump.
Old Aug 13, 2012 | 06:46 PM
cstone94's Avatar
Oops... Can you tell if that small gear is upside down? How should it seat in there?
Old Aug 13, 2012 | 07:00 PM
jonbonesjones's Avatar
Moderator
it looks liek its in wrong, the gears dont line up
